Lou the mower killer
- Jun 25, 2022
- Threads
- 1
- 8
I have a John Deere L110 ( Kohler 17.5 ) that quit running. I was mowing and on my last strip the engine slowed down to where it was running at about half the speed of it's slowest throttle setting. I stopped where i was and just sat there for about 30 seconds and the rpm's picked back up so i finished my last strip and headed for the shed. A few feet from the shed it stopped running and hasn't started since. It seemed like a fuel issue so i replaced the fuel filter .didn't help. So i replaced fuel pump and also new Carb. No start. It's getting fuel but replaced all the fuel lines when i put the carb and pump on. No start. So we checked and it wasn't getting any spark. Installed a new coil and spark plug and still won't fire. I tried pulling the kill wire off the coil which should bypass all the safety sensors but still won't fire. Ohmeter tested the coil and all the reading were in range on both coils that i had. Flywheel magnets are in place and strong because they suck the coil up to them with good force.
What else can i try , i don't want to keep cranking until i burn up the starter too. I even tried dumping a little gas down the carb but it wouldn't even fire once. I am lost. Thank you for your time.
