When I push the lever to go forward or backwards it is very jumpy(stiff). I lubed all the spots I can get to. I just got the mower and plan on changing the fluid and filter is there anything else I can do to make it smoother?
			:welcome:
happy now ?
Being a full on commercial diesel engined mower, users & service mechanics for them are a bit thin on the ground and even thinner on forums like this.
I can bluff my way through old variable stroke engines with mechanical lift pumps, but modern electronically controlled ones are out of my ball park.
Every couple of days you might like to reply to your own post with the :anyone: smilies found in the "more" section under the 15 on the right hand side.
We consider this a polite way to push your post back to the top of the new posts list.
What is the SD deck?
