northcreeek262
- Aug 21, 2018
- 63
Check valve port plugs will only defeat all rear wheel drive(I found out). Instead I bought two new check valves on ebay for $11 each and modified them to be permanently closed. I drilled and tapped for a 10/32 thread and used 3/4" allen head screws with locking nut (screwed in to bottom plunger into seat) after coating screw with blue loctite.
Nosed it into a ditch and backed right out, never would have before. Drove it up/down several hills, did turns, reverses,etc. and noticed no drivability issues. I did notice that if you do a fast reverse you could spin the rears on wet grass but, real 4wd is what I need.
Mowed some rough stuff today for about an hour, now with forward/reverse 4wd. Worked perfectly with zero issues and rear traction motors were no warmer than the front. I believe that many of the concerns expressed to me by dealers on this subject were just educated guesses with no first hand experience.
