Jacobsen 628D
helomech
That is what I figured, the rear wheels locking up in the previous post is what I say is bogus. I am a helicopter mechanic, I do understand hydraulics.
northcreeek262
This user does not have permission to use the HTML BB code.
northcreeek262
Another dealer response: Unfortunately there is no way of making the turfcat go into 4WD reverse, as far as traction upgrades are concerned there is a differential lock kit available, but it will only affect the front wheels.
MTE Turf Equipment Solutions,Inc
33 Thruway Park Drive
West Henrietta, NY 14586
Phone 585-334-0100 ext 1124
Seems odd that you would have a locking differential on a machine without a differential ?? again I think they are talking about a differential "type action".........what say you? Mike.
helomech
The check valve could easily be removed and a plug put in instead. That would allow for flow in both directions.
buzzzmeister
I was just asking if there where others that kept up with the jacobsen section still.
I check in here now & then but my current Jake interests are the old 60 & 72 Commercials (click on Phoenix link) and the HR15 & HR9016.
northcreeek262
I am not to worried about it, only ran into a problem once. My place is rarely wet.
Replies are still coming in, here is yet another explanation ...:confused2:
On Aug 30, 2018, at 8:25 AM, Laurita, Ron <rlaurita@textron.com> wrote:
Michael: The unit you have, and this is true on most 4WD units, will disable 4WD in reverse. It is done this was for safety reasons. The reason is if traveling downhill in 4WD and you move the pedal to neutral or slightly reverse to slow down, the potential to loose steering ability can happen. So we disable 4WD in reverse.
Jacobsen Technical Support
Asymair95
Fellas,
Was wondering if you could help me get smart on these Jake front mount mowers. I am in the upstate NY area also.
My propert is pretty hilly and wet sometimes, so I would need the 4 wd for sure. My question is about the ability of these machines to handle rough terrain. I have a few acres of old pasture I mow and it beats the life out of me on my zero turn. Do these style of mowers handle the rough stuff pretty well?
I’m on the lookout for a used machine in the Albany area. How did you guys find your machines?
Thank you for the help, Joe
Boobala
Oh okay. Mine is the 72" right side discharge.
And every so often ya get a smart-arse ( me ) ... to add some nonsense in .. like mine is a butt-hole discharge, was born with it, and after 71+ years it still "toots" loud N clear but on occasion has needed Metamucil to function properly.. :laughing:..:laughing:
