SeniorCitizen
- Aug 28, 2010
- Threads
- 143
- 2,302
So go ahead and invest more money into that foreign crap economy rather than making it work as intended. To each his own.
Hot melt glue does not have the strength for this purpose .If it were me, I'd try using a hot-melt glue gun. A big glob of hot-melt plastic filled between the cable and plastic housing should hold.
Thank you. That was very helpful.They are the sort of things that rat bags do in order to sell a turkey to an unsuspecting mug for profits .
Looking at the picture is that a hole on the hex where the spiral metal cable goes? It may have had a set screw in it that fell out. If not you could probably pull it back and drill and tap a place for one.Please see the attached picture. My choke cable sheathing moves from the housing each time I try to use it. IF I hold it in place, it works, but I would like to fix it if possible.
