- Nov 29, 2014
- 65
- 24,995
I am not trying to be critical of you and your are quite correct in that you should have been advised about this problem.
Honda appears to be the only company that actually does this and then it is only for the customers who complete the product registration.
I have never bought a new mower and have no plans to ever do so in the future so have no idea as to weather companies like Kohler actually keep customer records for the purpose of recalls & service advise notifications.
OTOH the mower should have been checked every time before use.
And if that was done the little sparkling fragments of the ground down bolts would have been clearly obvious.
When the crack first started a significant amount of oil would have started to leak out of it and that should have been obvious as well.
Apart from the visual the sound of the bolts being ground down should have been enough to alert you something was wrong.
It takes a long time for the bolts to back out enough to contact the flywheel and a simple turning of the flywheel by hand will produce a lot of grinding noise and be substantially more difficult like the mower was having a hydraulic lock.
You say the engine is beyond repair so there must be a lot more damage than just the crack.
The mower I am doing right now belong to a sporting club and had less than 100ml of oil left in the engine .
There was only a few dribbles of oil on the floor where it is parked so I would assume that they had been mowing the 2 acre of the field every week with almost no oil in the engine.
SO if yours blew up you must have been running with the crack for a long time.
The previous one I did belongs to a contractor and he noticed that after about 1.5 hours of use the engine would cut out which is why he brought it in for service thinking he had a fuel pump problem.
I noticed the oil was low so topped it up and mowed for 2 hours with no problems apart from running low on oil again which was tracked down to leaks from the crack.
So if you have totally destroyed your engine then you have not been taking as good care of it as you think you are.
