intek 12.5 hp engine cylinder head gasket need to confirm part #
outdoorpowermike
  • / intek 12.5 hp engine cylinder head gasket need to confirm part #
.004 is correct. Both valves. At top dead center on compression stroke. Beware that intake valve is the lower valve. Sounds like valves not adjusted correctly, battery low or compression release broken.
