I have had experiences opening transmissions. Every time they drop in value to below 0. The tolerances are too tight. If you do not have the tools and the 'sterile' area AND the expertise to do anything to that specific transmission, you just ruined it by opening it. A lot of the transmissions will tolerate a lot of use, if you do not stress or heat them up too much. I had a Hydro-Gear that lasted 20 years and its still going. Before, there were just gear shift transmissions, pretty simple. The hydrostatics now are like the automatic transmissions in vehicles. You just do not change the oil yourself in a automatic transmission. Save yourself time $ and frustration just buy a new one or have the company work on it.
