Keith Lovejoy
I have a Hustler Pro Raptor that I just changed the oil, plugs and Fuel filter on. It is now running fast then slow and keeps doing it. Any suggestions
I also changer the air filter at the same time.The Engine isa Kawasaki 23 HP FR691V.How was it running before you changed the oil, plugs and fuel filter?
When was the last time you changed the air filter?
What’s the model number and serial number?
What is the engine model number and serial number?
Makes absolutely no difference to the operation of the filter.Is the arrow on the fuel filter pointing in the correct direction?
