Hustler Rapture running rough
Keith Lovejoy
I have a Hustler Pro Raptor that I just changed the oil, plugs and Fuel filter on. It is now running fast then slow and keeps doing it. Any suggestions
MParr
How was it running before you changed the oil, plugs and fuel filter?
When was the last time you changed the air filter?
What’s the model number and serial number?
What is the engine model number and serial number?
Keith Lovejoy
I also changer the air filter at the same time.The Engine isa Kawasaki 23 HP FR691V.
The Model # is 937854
Dirty carb or fuel delivery issue. Check for vacuum leaks while you are at it.
MParr
Is the arrow on the fuel filter pointing in the correct direction?
Scrubcadet10
Moderator
Staff member
Oh dang... a hustler Rapture.....:oops:
Makes absolutely no difference to the operation of the filter.
The only thing is the crud will build up inside the element so will be hard to see when it needs replacing .
hlw49
What probably happened is when the fuel filter was change a little bit of junk got into the fuel line and into the carb. May be stuck in the inlet fitting before the inlet needle. Or worse case scenario deeper into the carb. Had customer bring one in the other day with one of those cheap after market filters in it and you could shake the thing and the element would shake inside the filter housing. I'm sure it did a great job of filtering the fuel. There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey. John Ruskin.
clubairth
Maybe junk but I had a similar problem. Changed the fuel pump not it. Took all the fuel hoses off and reinstalled them. Fixed the problem. Appears the fuel system was sucking air at one of the connections.
An air leak into the fuel system will give you a surging problem.
