Mad_mat222
- Jul 12, 2019
- 79
Are you sure about that? I thought it was a press fit onto the shaft. The riveted sections were part of the clutch assembly. The pulley is not part of the clutch and is only connected via the shaft.
That diagram is misleading. Have a look at an actual assembly like the Warner clutch. Nothing attached to the pulley.
