cbr7380
- Mar 11, 2023
- 40
so yes on the amazon one?And yes.
thank you sir ordered it from amazon now if i don't screw it up changing it out lolYes
And Dorman one you posted is a different connector series but is used in some connectors on some mowers.
@StarTech I got my tester light out and the B had no power to it with the key on or off? I even pulled it out of the harness and touched all around the connector and nothingthank you sir ordered it from amazon now if i don't screw it up changing it out lol
yeah a fuse by the battery and solenoid its okayThen most likely the fuse is blown or the fuse holder is bad but test for voltage at the fuse holder first as the problem might further the road.
think the wire is bad going into the terminal connector? its kinda kinked due to pushing back up into the harnessThen most likely the fuse is blown or the fuse holder is bad but test for voltage at the fuse holder first as the problem might further the road.
