Husqvarna YTH1842 ignition switch wire question
cbr7380
Okay so lately my mower will start up fine and run and then it won't start..Every time it starts it runs and mows great. My question is this evening I found that on the back of the ignition switch where the harness plugs in to switch the Pinkish/Red wire isn't staying in the slot tightly,meaning it easily slides and pulls right out the backofharness? Could this be a culprit? TIA
That should going the "B" terminal and is the main power to the switch. Yes it needs replacing with a new terminal. Being will cause intermittent power the rest of the mower.
cbr7380
tha can i use existing wire with new terminal or a whole new harness?
Well if believe the OEM then it is whole harness. More money for them.
But i regularly replace the terminals and even the housings. All you is a pair wire cutters, the terminal, and the open barrel crimper. And may a pick to remove the old terminal.
A local mower shop should be able supply you the female Aptiv F56 terminals but some are too stupid to have them.
cbr7380
is there another name they might go by? And is it 12 gauge? Tysm
Delphi and Packard are couple older names.
It should a 16-14 ga wire. Google up using PN 2965867-L.
cbr7380
would this work?
or this one?
And yes.
img_0951-png.65760
