Repairs How to remove carb. on a Toro 21" rear bagger
trooper1954
Thanks Engineman,
All done, plus replaced fuel lines and filter, and changed oil for good measure. Just about to see if it will start!!!!:laughing:
trooper1954
BTW, does anyone know what the compression should be on this mower?
Thanks
EngineMan
I don't have a manual on this one, but would say somewhere around 120psi would be fine.
trooper1954
:thumbdown::thumbdown::thumbdown: Well....all back together, new fuel, 30 weight oil, new fuel filter and lines. Will start but runs like the choke's on, and then dies. After two pulls to try and restart, the plug is soaked. New plug? It's the only thing I haven't changed, but it seems to be a fuel problem still :-(
BTW, thanks for the help and your patience with this....what do I do now??:confused2:
EngineMan
Did you do the carb..?
trooper1954
yep...as per your instructions and the diagram. Perhaps the carb needs to be adjusted or I somehow didn't hook it up correctly....seemed fairly straight forward but......
EngineMan
And what about a good spark, try a new one just to see if that would work, and recheck th carb. did you do a compression test in the end, and what was it.
trooper1954
No...didn't do a compression test yet....that will be next on my list. I'm thinking that maybe I did something wrong when I re-installed the carb.....maybe something is loose and sucking air....anyhow I'm going to take another look and make sure the choke lever/butterfly is working as it should, and that all lines are tight. the gaskets all looked good but maybe I should have changed them anyhow. I'll try a new plug as well.
Cheers
KennyV
If the float is set too high you can run rich... :smile:KennyV
trooper1954
Thanks KennyV,
All I did was remove the float jet and clean it....made sure the hole was free from obstruction, and then re-assembled....how do I alter the setting??
