Pete Lord
Sounds perfect, did you consider powder coat instead of paint?
How about posting some pictures...?
& Welcome to the forum... :smile:KennyV
Hi Kenny,
I am also retired, in my case after 40 years with the same company
Power Coating is a great suggestion and I did consider it.
1 Power Coating is not necessarily air tight as it is platelets that are melted to each other and there is the possibility of voids that will allow the start of oxidation.
2 Think about the total surface area of all painted parts on a 61" Scag Turf Tiger. The quote I got from the local power coater was "I can't handle anything that large or that heavy"
3 The KBS if applied right will be so hard and air tight that it can't be scratched with a screwdriver once cured.
There are a couple cons,
1 The second coat and the top coat must be applied between 2 hours and 4 hours of each other for the desired cross linking to occur.
2 It's catalyzed by absorbing moisture out of the air, so once the can is open, saving any for more than a week or two is impossible.
3 It's very similar to Gorilla Glue except it doesn't foam and expand while curing.
4 The spray gun must be thoroughly cleaned between coats, other wise you will throw it away. There is no solvent for the cured material.
5 The cured paint is not UV stable, it will chalk and bleach in the sun if not top coated with an opaque finish, although, that doesn稚 appear to hurt it's rust sealing performance.
It's not expensive as far as urethane primers and finishes are concerned.
Check it out on their WEB page.
Stop Rust - Gas Tank Sealer - Gas Tank Liner - KBS Coatings - RustSeal in Colors
I have no affiliation except as a very satisfied customer.
I'll take some pictures as soon as I get the new tires on it. The old ones were a disaster waiting to happen as I have steep grassy hills that end in creaks on three sides of my property.
Regards
Pete
