What color is the oil? Milky color? Does the oil look contaminated and soupy? Pull the dipstick and smell it to see if it smells like gas or not?
Yes its milky color and smells bad
What i was thinking of doing is opening up the engine and drying the whole this real good but i wanted to know if there was an alternative or an easier way of getting the job done
If you keep getting the engine up to operating temperature and changing the oil and getting all the old oil out and putting in fresh. Now the new oil is milky I would say water getting into that engine somehow. Have you got someone playing games with you?? Gas will thin out the oil but not turn it a milky color. You are also saying it smells, Just what dose it smell of other then oil?
it has a rotten smell like burnt water and oil mix
Hi is the oil you are putting in new?
Or is it oil you've had for a while?
Get some new oil!
Or you might be having us all on and using the mower under water LOL
If you can.....
Strip the engine down and replace all gaskets & seals & get some new oil, if you still get water in the engine then buy a electric mower
All the best from the UK
Now that is a new one on me burnt water. Any water here in NY turns to steam without smell? This is telling me its not rain water. Just what is that neighbor of yours doing to that mower?
