Mad Mackie
The green solenoid wire goes from the key switch to a relay. I have been told these relays can fail and may be responsible for my failure to crank problem. Can you advise how to check the relay? I had tested the safety switches for continuity earlier but not for voltage and they were ok. What do you think?
Buy a new relay of the correct part number from your Scag dealer and install it. The green with black tracer coming from the relay plug goes to the electronic control module. When all the safety circuits are correctly positioned for cranking, the module will ground the relay and allow voltage from the key switch in the start position (green wire) to close the relay which in turn will operate the start solenoid and allow high amperage power to turn the starter motor.
Otherwise do as suggested and get this machine to a Scag dealer that has quality service. I'm out!!!!
Mad Mackie in CT:laughing::biggrin::smile:
