Need more information. What model honda mower?
Does it start when cold and won't restart when hot? Does it run good after it starts?
If it has a choke i would look to see that it is closing all the way when it's supposed to be
I couldn't get it to start today. It has an auto choke and the choke is closed all the way down. I have to get some carb cleaner to see if I can get it to run by spraying it in the intake.
How do I check to see if it is still under warranty? Does anyone have a link that will verify warranty information through Honda?
If the carb is faulty, it's warranty.
If you caused the carb fault, it's not.
From what I see the carb is no mystery.
Pull the float bowl and report back.
