- Nov 29, 2014
- 24,995
To make an unequivocal evaluation I would need to chop up the rod & look at the grain structure at the edge
You see an effect much like striping a lawn where the edges of the grains are all deformed in the direction of rotation where there has been no lubrication
There should also be significant discolouration on the cap and less on the rod. commonly called blueing .
If the bolt was loose / broken from new then the cap would not have been running true so would have more wear at the joint edge than at the rest of the bearing surface .
There would also be hammering damage in the middle of the rod where it got hammered into the journal every time the engine fired
I do not see evidence of overheating in the photos although to make a meaning full diagnosis a lot better photos with proper lighting would be needed
Without doing the calculations there should not have been sufficient force to shear the rod bolt and I would need some photos of the fracture surface to determine the mode of failure
While happy snaps ( well unhappy snaps actually ) are fine for the forum & face book they are of no use for an engineer who needs to see details accurately and in particular the real colours and clean dry surfaces so there is no reflection & distortions due to oil on the surface .
I have been involved in litigation where it was eventually determined that the motorcycle in this case had been run without oil in it prior to being delivered to the new owner
I have also been involved a lot of cases where the item had been run with no oil / low oil by the owner , then filled with fresh oil in order to make a false warranty claim
So the first question is was the mower delivered to you new in the box or ready to run assembled & supposedly checked by the dealer .
If the former then get a engineering / metallurgical examination of the mower and brief your attorney as there can be no arguement about it being defective from the factory thus Honda's liability.
Legal system vary but down here the full costs of the examinations are paid by the looser plus extra for inconvienance & anguish so check that first .
However if it was delivered ready to mow then your claim will be against Honda & the dealer because the dealer could have been responsible for the damage .
These are near impossible to prosecute as or instance your mower could have been a display model and 1000 kids could have pulled the starter rope with the engine being dry .
