pugaltitude
- Jan 11, 2012
- Threads
- 7
- 1,142
I have had this problem before on a mower a few years ago.
Engine would start, run and mow for 30 mins then switch off and then not restart.
Also it would produce a misfire as if running on one cylinder.
There is various things to check.
The coil caps that plug on the spark plug are resisters and they can fail. a simple ohms reading test can
Show if they are faulty.
Also the same test can be done on the high tension and low tension of each coil.
Also the diode for switching the coils off to earth can be checked.
Also the you can check and make sure the carb antifire solenoid is always working ie voltage present.
And one last thing is to isolate the electrical components from the engine to the chassis.
Is it an engine fault or a chassis fault ie safety switch etc.
Mine was cap problem.
Changed them to normalspark plug terminals and it fixed it.
