Gord Baker
- Aug 21, 2018
- 1
- 490
Try straightening it, then when it is close SELL IT. Not worth the repair effort or cost.
Honda motorcycle service books used to tell max runout that could be fixed and how to straighten with hammer, v-blocks and dial indicator.My 2 cents. I had a Briggs with a bent crank shaft. Put the mower on its side, found the high side and hit it with a small sledge. Brought it back in close enough. I'm sure the Pros don't want to hear this but it worked for me. What did I have to lose. I continued to mow with the machine.
