Help! Scag Tiger Cat 2 Shuts Down
Work through the wiring diagram and check that none of the wires that are supposed to be ground have voltage on them or you will blow another $ 280 .
Franchise Scag dealers should have a diagnostic plug that replaces the tiger eye to diagnose wiring faults.
You can do it with a multi meter but you will need a set of very thin probes used for computers
The issue was the Tiger Eye gauge. It has been replaced and is now operating as it should.
If it fails again within the season then you have a short some where in the wiring
Try to keep the mower indoors when not in use and if you are in a heavy dew fall area the put a cover over the Tiger Eye.
