Work through the wiring diagram and check that none of the wires that are supposed to be ground have voltage on them or you will blow another $ 280 .
Franchise Scag dealers should have a diagnostic plug that replaces the tiger eye to diagnose wiring faults.
You can do it with a multi meter but you will need a set of very thin probes used for computers
