Hey ya'll, just recently joined the forum when I had an issue with my LT1000. I have been lurking around here for a couple of yrs now. Theres a lot of knowledge on here and always is the first place I come to with problems. I am looking to buy a new rider, either the YTH24k48 or the YT 3000. I have about 3-4 acres to cut and a whole lot of leaves to pick up in the fall. I currently cut with the LT1000 (can,t remember what yr I bought it but it is at least 10 yrs old) and in the fall i hook up a Agri - Fab yard vac that weighs approx 300 lbs empty and closer to 500 lbs when full. I am needing a rider that will pull this yard vac. I am not sure how the hydrostat trans will hold up to this and also on the hills which are not real steep. Seems like from what I have been reading the hydrostats are not very strong with pulling something heavy. I do all my own maintence and repairs. I change the oil 4-5 times a yr since it gets used yr round. Are the 2 mowers that I listed capable of pulling or do I need to look for riders with manual trans? Any help with this is greatly appreciated.
Thanks Mike
Thanks Mike
