Re: Help: Lawn-Boy 21" SilverPro Series, 10247, DuraForce (2-cycle) behaving badly
Ah, Lawnboy starting issues. That's a first. :smile:
All kidding aside, I'm surprised I'm such a fan with all the issues I've had with my L21zsm over the years. But like I posted in another thread, I've become so good at tinkering with the mower, I know it better than any mower I have ever had. Because I have worked on it so much, I am pretty confident that it will start and mow... most of the time anyway.
I know it's maddening when you can't get a mower started and then suddenly it starts, and than does not start again. I've had that happen to me on the LawnBoy.
I've had issues with carbon and sludge in the exhaust ports and muffler causing starting and running issues. I've had Carb issues galore. I've taken apart and cleaned and serviced the Carb four times since I've owned the mower. I had a governor issue causing me grief for an entire season, only to find it was simply a dirty pivot point and nothing more. A few shots of carb cleaner on the pivot at the bottom of the wind Vane and some penetrating oil and it was finally fixed after a summer's worth of misery. I had a spark plug new out of the box that was bad. I have had a fuel tank vent clog and give me a headache trying to find out why the mower was dying after running for a while. And I've had problems with the ignition coil(s). This last one is OEM and has lasted me 3 years by the grace of the almighty. Lucky I guess.
Your Duraforce is one hellava motor. I'm sure you'll get it fixed. Once you do that's another notch in the knowledge belt. Over time, if you stick with it, you'll become good at diagnosing and servicing it. Trust me. When I first bought my LawnBoy, I only checked Oil in my Snapper, put in gas and pulled the starter cord. Now with LawnBoy, I am more like I'm an old Steam Locomotive Engineer and I've got to keep the old girl running through constant tweaking!
Some may frown on this suggestion, but have you ever bought a can of Ether (Quick Start Spray) and tried that? This is a quick way to start a stubborn small engine. Spray a little bit into the Carb intake and give it a pull. Chances are good it will fire up with that spray. I have started many stubborn to start mowers over the years with a quick spray of starting fluid.
