dewguy1999
- Aug 14, 2014
- 9
- 145
Re: Help: Lawn-Boy 21" SilverPro Series, 10247, DuraForce (2-cycle) behaving badly
Thanks. turfboy1997 also mentioned adding a fuel shutoff, could either of you give me an idea of what I'd be looking for and how I would go about installing it? Since dirt and grime act as an insulator I can see how it would hinder the cooling of the mower but I had no idea it could warp the carb, I would've cleaned it sooner but I didn't have any idea it was like that.
			Install a 1/4 inch right angle fuel shutoff and your problem will be solved.you can replace the needle and seat too but try the shutoff valve first and see what happens.Thank you for cleaning up your mower.gook and grime retains heat and warps the carb body
