Re: Help: Lawn-Boy 21" SilverPro Series, 10247, DuraForce (2-cycle) behaving badly
On the SilverPro series (as well as many others) the nipples on the gas tank and carb are slightly tapered. You can fit your 1/4" hose just fine. Use the clamps if loose.
Thanks. I think I discovered something that may be a problem with using the shut-off kit. When I looked at the kits yesterday I noticed that they were 1/4" ID, well, I looked up the actual Lawn-Boy fuel line #612782 and according to the pic on this parts site it's 3/16" ID (I think). If that's the case wouldn't that make the shutoff from the kit difficult to install with the existing fuel line or make the new fuel line too big to fit snugly on the fuel tank and carburetor nipples?
