Have 12+ volts, but still- starting problem
Lawnranger
rigoletto, does your mower have a hydrostatic drive?
rigoletto
hmmm, not sure what that is. I guess not, as I have not seen that mentioned anywhere in my manual. Also, if that required hydraulic fluids, etc, do not have any of that.......no fluids other than engine oil.
rigoletto
manual: "Model Series 660 thru 679 transmatic lawn tractors"
Mod 13A4667 F118
Years ago, I talked to a MTD tech and he said the 5th, 6th, and 7th digits in mod # is the model. So above, thats mod # 667.
does that help determine if its a hydrostatic?
rigoletto
Sorry, 3 maybe 4 safety switches on this one. Two 4 terminal safety switches (part number 725-1657A) and 1 reverse switch (part number 725-1643) and then if you look to the right hand side of the wiring diagram you will see a lead not attached to any part. On the seat breakdown they list a seat switch optional ( part number 783-0611)
meanwhile, Riv's homework- I got 2 swicthes a;lready- gonna find the other 2.....
rigoletto
heres 2 pictures: first pic- loose yell/blk wire is dangling. This I think is the seat safety wire, but not sure where it attaches. BUT, this shouldnt interfere with starting, right? This is a good thing if rider gets off, and engine dies, right? Its been so long since this ripped off- I cant remember how it works. Evidently, this probably didnt contribute to the nion start problem. I believe. Still, I want to find where it hooks up.....
rigoletto
Supposedly, in this pic, theres supposed to be a safety switch near the F-N-R lever shown here, but where is this switch? Thats why I posted this picture. See the lever in back? It just goes to a C type spring. I dont see a switch, let alone wire that would atach to it.
Lawnranger
heres 2 pictures:
Where does that yellow with black tracer wire go that is off to the left in the picture? The one that looks like the insulation is stripped back about 1/2".
Yellow/blackstrip is part of the safety switch circuit and needs to be hooked up. It runs from the seat switch and one of the two 4 wire safety switches you have found. Also, have you checked that fuse???
Also, look under the seat for one switch and by your shift lever for the other.
SONOFADOCKER
We have professional and home owners that drop off machines with NO START issues . A lot of times it's connectors packed with dirt and grass .
Your harness is simple . Just follow it . Unplug it clean it .
Let us know .
