robert@honda
- Nov 2, 2011
- 97
- 1,791
This is an EM-2500, frame serial number: EZCN-1049312, engine serial number: 3854913. I hope this helps.
Thank you for the reply, I really appreciate the help.
That is an EM2500X (K1) which is a slightly updated version of the original model (K0). K1 changes were to make the engine compliant with California Air Resources Board rules.
This specific serial number was wholesaled by Honda to a dealer in Burnsville MN, on 2/12/1996. There is no records of the first retail sale/customer on file. If you'll send me a PM with your name add address, I can update the database to show you as the current owner. Honda asks for this information in the unlikely event there is ever a Product Safety Recall and Honda can contact you.
"Only runs on full choke" is a classic symptom of a clogged main jet and or main nozzle (see highlighted parts):
Sometimes a good quality fuel system cleaner can flush out the slime/debris, but it may required the carburetor to be removed and completely cleaned. This can be done with some spray carb cleaner and compressed air, or, have the entire carb spend a few hours in a ultrasonic cleaning tank. As a last resort, it can sometime be cheaper/faster/easier just to replace the carburetor, but this list price on a whole new one is $51.87, so a cleaning might be best to try first.
The carb should be removed from the engine for a proper job. This is quite straightforward on the EM2500, and be sure to have a clean well-lit workspace when tearing down the carburetor. A shop manual will help tremendously with this job, and Honda sells paper copies on eBay and Amazon, either with free shipping.
Honda Power Equipment Shop Manuals on eBay
Honda Power Equipment Shop Manuals on Amazon
