djdicetn
I need to add lights to mine also, I need to mow after work if the weather is bad on the weekend. I was planning on using led's to minimize the battery draw, but they are very expensive for decent ones.
Have you had any issues with the 55watt lights you used?
Thanks,
Rob
Nope, that kit is inexpensive and I have had no problems with it, the battery or charging system since installing it. Works great for the money!!
