Hi everybody,
I just wanted to give my thoughts to you on the honda hht25 and hht35 straight shaft 4 stroke trimmers.
HHT35- i bought this one first and i love it. Only 1 single complaint. It weighs almost 15 pounds. On the everything good. It is very balanced, nice handles and controls, very very easy to start, runs really quite (typical Honda) true 4 stroke so now 2 stroke fumes giving you a headache when using it for a while, no mixing any oil just 10w30 in crankcase and very easy to change, silk smooth power delivery (unlike stihl 4 mix way to light switchey) very low maintance, easy to change headl.
HHT25 I bought this one afterwards and honestly it is just like the 35 but definetely lighter 13lbs and a little less torque but everything else is identical with exact same charastics. I definetely like how they didnt cheep out (honda) and built a proper 4 stroke using reg 87 gas with good oil lubrication in the bottom end and you can turn and rotate it 360% all day long no harm. I know so many people getting away from 2 stroke gas but then all of these companys make 4 strokes that use 2 stroke gas/oil for lubrication. If you going to go that route you would be dumb not to just get a 2 stroke in the 1st place. less moving parts and power to weight. Big reason i ended up getting the small trimmer is , weight and you never use the power that the hht35 has unless your in really high grass (weeds, fields etc) Great Units Highly recomended especially if you looking TRUE 4 stroke. And No the valves dont go out of adjustment like some other models that are out there. Every check your honda mower how often those valves go out. HAHA thats what i tought. Like never.
