mitchstein443
- Nov 2, 2018
- 55
I just got a ryobi electric mower.. and I love it!! I got the small one with 50ah battery about 2 months ago and it mows my backyard and to neighbor yards on a single charge, yards are like 25x150 feet has a 32" deck..
My neighbor who has 2 acres just got the 200ah ryobi and he mows his whole 2 acres no problem 42" deck..
So I tested my little tractors towing capacity..
Moved a small block chevy about 50 feet while sitting in a garden trailer no problem at all.
Trying to pull the 1995 yukon back about 10 feet from the garage door (in order to remove before mention small block) it kept popping the front wheel off the ground so e had my helper stnd on the front of the mower and it moved it back 10 feet with no problem, from concrete flat to grass.. worked about as well as my 22hp craftsman with hydrostatic trans (dyt4000) for moving the vehicle) also towed my 1972 JD 400 tractor from accross the street to my garage with no problem, the jd weighs about 3/4 ton plus 200lbs for the deck. It was moved about 400 feet.. didn't even struggle with a 200lb rider on the jd to steer as well..
Now it just comes down to durability and we will know in about 6 months to a year how tht is, got a 3 year extended warranty though so not worry...
Oh and it cost just under 3k with bagger and bagger blades delivery and everything. very very happy sofar ad recomend it to anyone with a smaller lawn. The only donside is it takes 8-12 hours to fully charge from empty.. I get a little over an acre of mowing with it, it's rated at one, we went about 1.25 acres before it started beeping battery low. and we drove it around the block about 8 ties straight and the battery indicator still said 50%, got tired of riding it around in cirlces lol...
