FX691V oil consumption
lefty2cox
Come on guys take a step or two back and try to calm down. This is no place to be a PITA in each other backside. Meanwhile I head out to the doctor's to get a finger up mine today. How embarrassing to have a woman doctor to do it. Just it is a man doctor to do it to woman.
Oh my god...I thought I was the only one. I see her every 6 months. She's relentless...I put her off every time. I tell her I just had it done last month or it's on the calendar for next month with my other doctor. But recently, she called my bluff. There should be a law.
mmoffitt
just dump more oil in it till you have it "sussed out"...run what you brung!
TobyU
Sometimes, you can do a lot of things but often it's just not worth it. Sure, in some engines you might be able to rotate it to bottom dead center enough to actually try to slide a wrist pin or the circlips out to slide the wrist pin out of the piston and then push it back up and pull the Piston out or up enough to remove the rings but not often and you're increasing the level of difficulty and that increases the chances for error or something just not getting in the right place and having a catastrophic failure later. It's not pretty what a wristpin rubbing against the wall of a cylinder can do.
What kind of oil are you running in it? Usually it's the intake valve guides and seals that use oil as compared to the exhaust so you might just pop the spring and retainer off of that one and add an extra umbrella style seal on top of it which could eliminate most if it's leaking there.
Also the oil... Fully synthetic oils tend to find ways to disappear and get used more than conventional oils. I would be running a straight HD 30 in that.
I know others will roll their eyes but I have had great luck with one particular product in the entire line of them known as snake oil restore engine treatment.
I have used this in many engines and small engines at a good strong 20% of crankcase capacity and sometimes pushing 25% probably and I have had great results.
Dreaded
Curious. How the heck are you installing the piston(s) from the inside the crankcase? I have always removed and installed them from the head side here. The only I install from crankcase side is on hand held two cycles.
I suggest the OP get a copy of the service manual and read it over before attempting anything.
I have done this several times and it is not very hard. First off There is two ways I have done this. I remove the pin from the piston and only one ring from the pin. I put the piston back in using a ring compressor then push it to the bottom of the cyinder just enough for the pin to go back in then I put the ring in holding the pin. The I ease the cylinder back down on the piston. But you have to be very carefull doing this.
The second way is if the cylinder has a tapper on the bottom which most do have. You can take your fingers and compress the rings as you slide the cylinder down. I have done this several times when the piston had to came back down to far and exposed the oil rings before the pin would go in.
I do this when there is no problem inside the engine and just reringing the piston. If there is any damage to the piston or the cylinder a complete rebuild would be in order. The rings are harder than the cylinder wall so if you are careful they will not be damaged. I have never heard of the piston has to be inserted from the top side.
I have rebuild several twin engine mowers and never had a problem. Any engine with new rings if not broke in correctly will start using oil. My customers have been running engines I rebuilt like for years with no problems. Just because it is a redneck way does not mean it is a bad way. My father was a master mechanic and showed me several short cuts that work but is not in manuals.
I appreciate what you are saying, however you have to remember the target audience .
I also appreciate that in a full time workshop the situation is vastly different to in the shed of a very much amateur .
In my workshop I can ( usually ) do a full & proper diagnosis so end up knowing exactly what needs to be done and if I am busy limit the job to just that .
However I do like to do most jobs the long way so I can do things like examine to bore & pistons fully which is difficult to do with the rod still in the engine .
So while you pappys short cuts are a valid way of working , they are for discussion amongst professional or fully competant engine rebuilders and not on an open public forum where the bulk of the people are total novices.
As you know the rods on these engines are quite frail and easily twisted or bent by people whacking the pin with hammer .
I have a box full of pin clamps ( somewhere ) to push pins out without damage but I doubt that any standard home owner would have them.
Also there is a big difference between working on a vertical twin & a car engine.
By the time the engine is pulled from the mower , sump is off , head is off & rod cap is loosened /off there is not much to be gained by not pushing the piston all the way out .
Again if there is 20 more to be done then yes the 5 to 15 minutes of time saved would be significant but on a single one off job not really .
7394
Meanwhile I head out to the doctor's to get a finger up mine today. I go on Monday.. Fun, fun..
JD X485SE
I don't even change my own oil anymore - not because I can't but because I don't have to. But let's be honest, this stuff is not brain surgery. I can't imagine the OP couldn't find a youtube video to walk him through what he needs to do.
