In
We sometimes think a 10,000 rpm 2 stroke engine will have a hard time sparking that fast but in reality it is a non issue. Cranking speed or 14000+ rpm the magneto puts out the same energy. Consider my 1966 396cid chevy with a standard 3 ohm coil and points. Turning at 6000 rpm the distributor is turning 3000 rpm and opening the points 8 times per rev. 3000 x 8 = 24000 spark pulses per minute. Above 6000 rpm you needed a magneto or a dual point distributor. The operating speeds of small engines from cranking speed to 15000 rpm is insignifigant to a magneto ignition. Some chainsaws have speed limited coils. At somewhere around 12000rpm the saw starts "blubbering" and folks think the coil can't keep up when in reality it is designed that way.BTW, do plugs throw a thicker spark at lower RPM's? Say like when one is being cranked?
