PTmowerMech
- Apr 16, 2018
- 396
- 3,018
BG55 blower I'm just checking things out before I start fixing things. (the carb replacement)
120lbs of compression (tested 3 times)
Good spark. Replaced the flywheel with a used one.
Removed the spark arrestor.
I've used carb cleaner in the plug and got nothing.
Poured a little mix into the plug hole and still nothing.
Also tried putting those things through the carb.
Those things are proven to work. I'm not worrying about it running right, right now. Just want to get it to crank, even for just a seconds. Am I'm missing something?
