PTmowerMech
- Apr 16, 2018
- Threads
- 440
- 3,392
You can flood an engine with sprays every bit as much as you can with a liquid fuel
Next time you find yourself in this position try warming the plug & / or the cylinder with a hot air gun.
The fuel : air mix burns at the same speed regardless of what it is in or how fast the engine is spinning.
So to burn completely before the exhaust port opens, high speed 2 stroke engines need a lot of advance .
With a timing chip, this is actually ****** because at STP you can slow electricity down but you can't speed it up.
So with most 2 strokes the timing at starting is right on the verge of being too far advanced thus it becomes critical that it is exactly right.
On 4 strokes that are only spinning at 1/2 to 2/3 of a two stroke the timing is no where near as critical .
Ok (with the exception of flooding), that doesn't explain how if there's fuel in the chamber, and spark, that there's not at least some sort of explosion. If I'm understanding your right, you're talking about things working as they're supposed to. But I'm still confused as to how there's no explosion. '
Or is there one, and it's just not audible?
