- May 6, 2010
- 12,007
Unless you have a special engine on a piece of equipment that you don't want to part with, it is more feasible to just replace the engine if you want to keep the piece of equipment, and feel that it is in good enough shape to cover the expense of a new engine. New engine come with warranty.
trying to trade in a mower with a non running engine kills the value. Since the dealer that you are trading it into doesn't know what it will cost to repair, he will most likely assume he will have to put a new engine on, so that will come off your trade in value.
Rings could cause low compression, but doesn't account for the cylinder with 0. That is something else.
