- Nov 29, 2014
- 64
- 24,745
No idea about the springs in the pump unit but as it is spinning quite fast centrifugal force should force the balls out and I expect the cam pushes the balls in creating the pumping effect.
If you have not lapped the plates then I doubt the tranny will work.
The volume of oil pumped is very very small so given the chance of passing between the two oil galleries via the scoring or driving the wheel motors, the oil will follow the path of least resistance.
Now it could be nothing more than at those speeds all the oil passes through the scoring and when spinning faster, enough oil passes through the engines to get them to work.
