- Nov 29, 2014
- 64
- 24,745
You are already beyond my level of experience so I would just be guessing.
Eaton engrave serial numbers on their trans and usually rivet a plate as well.
Even though it is a cheap mower unit Eaton were very good to me.
Sending an IPL + a service manual which looks the same as what you have posted
measure and photograph it clearly ( use a stand of some sort) & drop them a line.
I am not sure how much scoring is permissible in these units.
Generally with others I have worked on, If you can feel the scoring with your thumb nail, it was considered US.
However none of them had a charge pump and I have no idea if the bleed by would be significant or not.
