Hammermechanicman
- Jan 10, 2020
- Threads
- 56
- 3,548
The voltage regulator really has nothing to do with the ignition system if i read the service manual correctly.
Question: do the coils have a single tab for a single wire and not a multi wire connector? If so remove the wire from the coils. This eliminates something grounding out the coils. Set the coil to magnet gap the thickness of a piece of cardstock, about 15 thousands.
Stick a bolt in each of the plug connectors from the coils and position 1/4" from ground and crank the engine. If you get spark your ignition syatem works. It will run the engine. If you have spark the install clean dry spark plugs and connect. Now with throttle wide open and no choke spray about 1 second worth of starting fluid into the carb and try to start the engine. It should fire and run for a couple seconds. If it doesn't you either have a compression, valve seating or valve timing problem.
If you pull the kill wire off the coils and you don't get it to jump a 1/4" gap with the proper coil to magnet gap then you have a bad coil or weak magnet
