- May 6, 2010
- 51
- 11,246
I have found Kawasaki modules susceptible to cracking the epoxy in the modules and during periods of high humidity will cause the modules to short out. The ones that I normally see are due to a misfire, and when determining which side it is on will not start on either module if one plug is disconnected, but may start if both are connected,Don't use the plugs to check spark. Remove the plugs from the coil wire and insert a bolt in the coil wire and hold that 1/4" from ground and crank it. If won't jump the gap sand any rust off the flywheel magnets and adj the air gap if still weak spark probably needs new coils but both bad at same time not likely.
Have come across a few Kohler and Briggs with the same issue, but seems to be a 10:1 ratio for Kawasaki to other brands.
