- Nov 29, 2014
- Threads
- 64
- 24,718
by and large the only thing that the switch itself will cause the fuse to blow is if it connects the B (battery ) terminal directly to the G (ground) terminal.
After that it has to be a wire that is connected wrong.
So the next trick is to unplug everything one at a time till the fuse stops blowing starting with that alternator stator plug which I rather think is your problem as both the AC & DC
wires appear to be connected to some thing and you can not do that .
It could even be a bad relay
I use circuit breakers when on site because blowing 25 fuses becomes very expensive very quickly and of course the next job will need one of the fuses I have just blown.
IN the workshop I use a test light which is an old headlight with a blown element .
The Honda , Kawakasi and Briggs engines all had substantially different looms
The Honda has an oil & Battery light
The Kawasaki has an oil warning light
The B & S has neither
Each of those looms are different
And this assumes the loom that is there is the one that should be there and the Honda was in fact the original engine .
Get the B & S repower guide and read it a couple of times so you can understand what should be happening
When you fully understand how it is supposed to work, and in particular what connections the key switch should be making then you might have a chance to get it on the grass befoe the lions hiding in the log grass start terrorising your dog.
