Engine swap
Fredc2
Is it possible to swap a kohler 640 with a kohler 650.
hlw49
Post model spec and serial no. for both engines and someone will run the specs. and see if it is possible.
You can swap any two engines
If the PTO shafts are the same size then you can use all of the old running gear.
If you swap brand for brand then the controls & wiring SHOULD be plug & play
