H hlw49 Lawn Addict Community Leader Aug 25, 2021 #2 Post model spec and serial no. for both engines and someone will run the specs. and see if it is possible.
B bertsmobile1 Lawn Royalty Aug 26, 2021 #3 You can swap any two engines If the PTO shafts are the same size then you can use all of the old running gear. If you swap brand for brand then the controls & wiring SHOULD be plug & play
