Is it possible to swap a kohler 640 with a kohler 650.
Fredc2 Forum Newbie Joined Aug 25, 2021 Threads 1 Messages 1 Aug 25, 2021 / Engine swap #1 Is it possible to swap a kohler 640 with a kohler 650.
H hlw49 Lawn Addict Joined Jul 11, 2021 Threads 36 Messages 1,392 Aug 25, 2021 / Engine swap #2 Post model spec and serial no. for both engines and someone will run the specs. and see if it is possible.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 64 Messages 24,705 Aug 26, 2021 / Engine swap #3 You can swap any two engines If the PTO shafts are the same size then you can use all of the old running gear. If you swap brand for brand then the controls & wiring SHOULD be plug & play
