So I guess I need to buy a pickup truck to haul this damn snowblower in for maintenance every year?![]()
I have nothing but bad things to say about Seafoam plus its pricy. I use Berryman B12 in the can and its $3.19 at Walmart. I also use Star Tron or Ethanol Shield for fuel stablizer. Ethanol Shield recently came out with stablizer just for 2 cycle equipment.
I have used sea foam not that great but it dose work on some things ..I just got a ultrasonic cleaner to me it was a waste ..I do about 10 to 15 carbs a day ..Waste of money on the powder...Its cheaper for me to use gas and a sea foam mix and soak them clean them out with a needle and compressed air works like a charm ..With the amount of gas I get in that is flat it makes great parts cleaner
If you bought the HF powder it only works on jewelry. I buy cleaning solution from design technology for my HF heated ultrasonic cleaner.
I disagree with that theory if the gas is bought at Sheetz. Sheetz is watered down. I seen it destroy fuel injection systems on automobiles cause how much water is in the gas. But if gas bought from a Exxon or Shell then its probably poor storage practices.I think most of the "fuel is the issue" is BS.
I had a friend bring it back from the states for me ...I will see if I can find a place here that sells it as we don't have HF here ....
DaveB and Briggs, we have been using the HF powder for over a year in our shop and have had great success with it. Cleaner gets used at least three times a day and sometimes have to change the solution more than once a day. Four techs here swear by it.
The cleaning soution from Design Technology is much effective than that powder from HF. The cleaning solution from Design Technology isnt a HF product. You get it from tinytach.com. Stens ultrasonic cleaner and cleaning solution now also.
Bull$hit. Been in Central PA since 1993 and have used Sheetz for gas since then. I'd say I've got probably well over 400k in various cars with Sheetz gas. Never an issue with the fuel systems in any of them. From a carb'ed 1986 Mustang to a 2010 Taurus SHO.
Its true. It known to destroy fuel injection systems in automobiles. I dont even use Sheetz gas anymore cause I get poor gas mileage when using it.
Fuel used in small gas engines needs to be clean and water free. Passenger vehicles with multi-cylinder engines are more forgiving when using today's fuel.
I have been using Stabil. I'll give Sea Foam a try before pulling apart the engine.
I was just thinking to myself, "what other appliance do you spend $600 on, use it once, and then it's broken?!" I've found many people reporting the same problems I've had - and it's from one of the best rated snow blowers.
Sorry, I'm cranky after a spending a day of maintenance on the thing, and it still runs like crap. I should have just stuck with shoveling snow by hand.
Agreed, just sharing my OPE fuel practices. I add SeaFoam each time I refill my red OPE gas containers, not just before seasonal storage.like I said in my first post ..Fresh high test gas and a good fuel system clean and it will purr like a kitty ..And when u store ether run it dry or put stable in it let it run for 5 min to get the stable threw the fuel system then shut it down..It dose not matter what the name of the EQ is none of them like dead ****** gas ..When it brakes down it plugs up the carb or it makes them run ****** ....
That's what I do as well. On another note, I did have an issue with my blower this season. It was fuel related but not in the sense that we're discussing here. It would rev down a bit at full throttle and die when I released the trigger. Ended up that the H/L carb mixture screws needed adjustment. Runs better than new since they were adjusted. They're set very lean due to EPA regulations. Also, the mixture screws require a special tool to adjust. Could be that my mixture is a bit richer than what it was when I first bought the blower (I've changed to using Lucas semi-syn 2-stroke oil with 2/oz per gallon SeaFoam).I add my stabilizer before pumping the gas in my cans. I keep 10 gallons stored at all times.
Nope, Craftsman (aka Poulan) 25cc blower.
I don't know what anyone else pays for gas, but I have to pay almost 4 dollars a gallon. I sure am not going to throw it out after it sets for 30 days when everything I own just runs just fine with it. But do what makes you feel good. My next question is what do you do with this 30 day old gas, pour it on the ground ??? or pay more money to get rid of it?
Add an additive then you wont have to throw it way.
So you are saying if you don't add additives throw it away. Throw it my way I will use it.
I have said it before and I will say it again.
Bull**** on this whole ethanol crap. I as do many others let a mower or car sit for a couple months and it fired right up and gives no trouble.
Many of you just assume that ethanol is the cause of every no start or running bad problem.
You say you have seen what it does. Ok what test or study did you do to come to the conclusion that ethanol is to blame?
How many people come on here with problems that you say is caused by ethanol but they use no ethanol gas? A lot.
Ethanol is alcohol, alcohol attracts moisture, moisture attracts corrosion and corrosion put money in my pocket. I can't make it much simpler. If you are turning your fuel over in thirty days or less, there is very little chance that you will notice a difference. If you are a landscaper or drive a vehicle you will probably never notice a difference, because you never have fuel sitting around. The average homeowner likes to have a 2-5 gallon can sitting in the shed and here is where the problem occurs. As I have said before, we advice all customers to use non-ethanol fuel in all their small engine units. Yes, it does cost more (about .45 in my area) but at today's labor rate, we call it cheap insurance. Just like our customers, each of you must decide which route to go. Can I prove that this way is better, no. All I can say is that we have seen a drastic drop in the number of fuel related problems by customers who have changed and if I had a dollar for every customer who has said thank you because he has noticed a difference, I could take a nice vacation. Still clean and rebuild about a dozen carbs a week, so we still need to educate our new customers. Do what works for you.
If you are cleaning 12 carburetors a week you must have one big shop with a very big business. I have worked in big shops and never seen that many carburetor repairs. Now when you are doing all these carburetors they are full of water damage? It just must be where I am located when I take a carburetor apart I am more likely to find dirt or gum up from real old gas and not water damage. Now when I say gum up its from gas that has been setting for years not one season. Yes I have come across water damage in carburetors but find the carburetor by that time isn't repairable some times. Just my own experiences which are a lot different from yours.
Only have 3.5 mechanics working in the back, so I won't call it a big shop. Last Monday I had six carbs by myself. I have seen everything in the carb, dirt, gum, varnish, jelly, corrosion, etc. Have seen needles frozen in the bushing and I have one needle, which I saved, where the plating on the needle is peeling off. Viton tips and seats swelling up are the major problem. We buy Tecumseh part number 631021B and Briggs part number 398188 fifty at a time. Never had this type of problems until about 5 years ago. Before that may have seen one carb problem like this a week. Today's carbs are designed to run so lean and the jets and passageways so small, that it doesn't take much to create a problem.
I use my old wheel horse for snow removal . 8 months ago I parked in in a lean-to and turned the key off. Seeing we will have snow coming I wanted to get it running for the winter. Yes I did have some problems. The battery wasn't any good but that was three years old so needed a new battery. The bar that rises the snow blower broke which just needed welding. Now the gas tank is haft full with last winters gas. It started right up once I installed the new battery and it go's up to full power. No additives and no high test gas. The carburetor didn't need cleaning. Just why dose every one else have all these carburetor problems after there equipment sets for 30 days? I think its the additives and high test gas you are putting in you equipment. Or could it be the different climate that we live in? Or could our gas be different? I just don't understand all these fuel problems are coming from that I am reading about and I just don't see this type of work coming into my shop???
I know I get better results after I switched from Star Tron to Ethanol Shield. I told my Stens rep that and she never heard anyone else have trouble with Star Tron.
I think it's all the crap everyone is adding to their gas.
Like I have said I let mowers sit for months and they fire right up and run fine.
I let a buddy use one of my trimmers because his won't run right he has had it for two weeks now it only runs on half choke.
He uses a fuel additive I do not. So what your are saying make sense to me.
Just curious have you ever ran your equipment without any additives? If so just what results different have you seen. Also what different do you see between Star Tron and Ethanol Shield ? Do you buy a lot of fuel at a time and it sets a long time is the reason you are using Ethanol Shield?
