A lot of information has come my way
I want to thank everyone for contributing their ‘opinions’.  It truly has been informative.  I have been posting to several forums to try to garner as much info and beliefs as possible.  The lawn mower forum has pretty much sided with the Zero Turn (but was not too much in favor of the ‘Quest’).  The Tractor Forum(s) have pretty much sided with the ‘garden’ type tractor.  But….I suppose that should have been expected from each group.  I thank ‘KennyV’ for the video link; that was very enlightening.
The video kinda took me by surprise.  But not for its information.  The slope was said to be 16 degrees and from the viewing of it, it did not look that ‘scary’?  When looking at my slope it looks a tad scarier than in the video.  Soooooo, that got me to thinking….. I don’t know how to measure a slope?  I copied what was in the owner’s manual for measuring a slope.  I took my level with me, this time, and aligned the sheet of paper with the level and took a reading.  I came up with 15 degrees again with the one area slightly above that…..maybe 16 degrees or a tad more??  Maybe viewing a video is not the same as being there?
Anyway……I am at a cross roads again.  The ‘muscle’ of the tractor is impressive but one does sit higher than on a ZTR; which infers the center of gravity is higher?  Maybe that is why the John Deere rep said that I would need to put fluid in the tires to lower the center of gravity?  That does not make me feel self-assured.  The ZTR ‘looks’ like you are closer to the ground (the rider) but the video showing the sliding did not instill confidence either; but I realize he was forcing the issue.  With the eXmark the hand brake I believe is down by the feet?not good.  And there is NO foot brake.
I know the walk behind mower will work.  But at 22” that takes a long time.  There are other options of walk behind 26”-33” but they are monsters with all sorts of hand controls and stuff you gotta do and on a slope that does not instill confidence either.
I realize my situation requires I get off my wallet……which I’m having a tuff time doing.  I see so many tractors and ZTR’s at around $2K, +/- , but none of them can work in my situation….so I’m told.  Spending $3,500 minimally and more than likely over $4K+ is hard to accept.
For those of you who recommend used……….there is absolutely nothing available within 100 miles of here…….I’ve called/checked.
I guess I’ll be ‘walking’ a bit longer unless other opinions/views sway me.
Thanks.
