DLT3000 - Mower engages but inconstisent
cxcal1
Thanks..
I order the carriage bolt and the spring.
Carscw
That was fast.
If you can put the spring on this fast please let us know.
(( racing is the only sport that you need two balls ))
cxcal1
Ok.. I was somehow able to replace the clutch cable without removing the deck.
The carriage bolt came with it, but I can't tell how that bolt comes out of the pulley.
Any suggestions?
And the cluth cable did not resolve anything. I still have tons of play in the v-belt when the mower is engaged. Is that normal?
mower blades still continue to stop when it hits high grass, and slowly comes back when idle on level ground.
