That sounds like something I would like to try out(the way you cut putting greens). Are you saying "each time you mow the green" you change the direction or you use the "clock method" during a single mow????? You did say "next time".....but I wanted to be sure I am interpreting you correctly. Is that an original idea of yours or did you pick that up from another commercial cutter? Sounds like it would indeed enhance the striping look!!! Just mowed my yard yesterday for the first time this season(been getting a LOT of rain here in middle TN, but it had been two days since we got any). We had a bitter winter and the grass hasn't established well yet(it was mostly green onions:0) I bought and installed the Gravely "hex striper" kit last fall but this is only the third time I've used it. When I get my yard looking just like I want it I'll post some pics!! Hope your doing well.....later.
Ha ha I am getting the same rain. I hope we don't get as many rain days as last year.
When I worked on the golf course we cut the greens every day ( bent grass ) and sometimes twice a day in early spring and late fall.
Every time we cut it was a different line. And every other cut you did a clean up pass. One pass around the outside. One day would be clockwise the next time would be counterclockwise.
I keep my Bermuda at 1/2 inch I cut every 3 or 4 days with a toro greens master.
If I was using a rotary mower I would cut every 5 to 6 days at one inch.
If you have grass that turns brown in the winter you can spray the weeds with roundup without hurting the grass.
