That one thing Briggs doesn't do and that is to keep charts and service manuals up to date. That's why I posted the supersede list so each of the previous number could be check against the chart. Some of the service info has been outdated for some time.
In this case it is just better to install a 9+ amp AC stator and used the rectifier/voltage regulator if the customer is wanting to do anything other than recharge the battery. Something like the tri circuit stator.
It is like the Briggs engine spec charts that are out of date. I have a personal copy of the non Vanguard chart that I have made numerous notes on as new updated SB and DSB info was published.
